Some porting work. Inlet valve seat is ported slightly offset or is it called eccentric? Approx 1mm offset. It will use hand ported seat angles, no more 3 angle valve seat.. 43mm inlet valve/90% throat diameter
Exhaust valve seat throat is oval, approx 1mm. Now short side radius is mutch better, and now more any turbulence at the exhaust port.
I cannot take better pick´s, my camera is not good enought, or my hand is shaking to mutch..
Inlet flow will increase approx 35-40hp over stock 3 angle valve seat when make a test after porting.. But that flow bench testing is not the point. Only i want to show how this make a difference.. It is only some theoritically number. But now it will flow ~200cfm if some one is intresting.. Now it will use short side mutch mutch more than STD 3 angle valve seat/85% throat diameter.. Theoritically my flywheel power 393hp + 40hp more head flow + more agressive cam, it could be produse 40hp more.. wink + some home made merge collectors.. Those are ready now, in the pick they are still in progress..
