I have described a good way of setting up the pilot screws in the link that I sent to you, it has worked well on every engine that I've done. (Checked with a lambda probe)mk1storm wrote:Ok, cool. Will take a look in the next day or two and let you know what I’ve got in there.
Mike – To try and sort the transition between the idle circuit to the primary main jets (without fiddling with the accel pump – currently on outer most of the three holes by the way, was initially on middle hole) would I tweak the idle mixture screws or would the change of primary main jet (or both) sort this?
For additional info, the idle CO figure measured recently during the IVA test for my car (kit car) measured 2.7% ish on both banks I think it was (limit of 3.5% due to engine age)… I went for the rule of thumb 2 turns out on the idle mixture screws I think it was. Sound like they’re set too lean?
The transition circuit is not adjustable on the Eddy carb, the pilot screws will have very little effect on this circuit although they may be feeding a very small amount of fuel into the venturi when the transition slots are also delivering fuel. The actual order of the flow of fuel is the curb idle circuit first which is adjustable via the pilot screws then to the transition circuit which is not adjustable. It then goes to the primary main jets with the rods in the low position. It then goes to the primary jets with the rods in the up position. The finial circuit to start delivering fuel is the secondary jets. There is an overlap between the circuits.
I have found that the accelerator pump can dump in too much fuel into a 3.5, when I was running a 3.5 I made an extension to the pump arm to reduce the shot. Two turns out for the pilots is in the ball park but is probably a bit lean, this would cause the pickup to be a bit jerky.
If your issue is that the car surges and does not respond to the throttle well say at 40 MPH and the fault is in the carb it will be the cruise circuit that is too lean.
At the end of the day you need to get the carb and the ignition sorted out if you want to get the maximum performance out of the engine! You need to know what jets and rods you have got fitted and what the critical figures of your ignition system are.
