High Hydrocarbon readings
DaveEFI wrote:Does this version of hotwire do any 'learning'? It would help to know the age.
It's likely to learn its way into the bin to be honest - we have a megasquirt already for it (bought from a member on here), we just didn't have time to fit it before the IVA.
Also I was worried about fitting the lambda boss onto the exposed exhaust pipes from an IVA point of view, but our tester was really helpful and explained what we could get away with. Essentially I just need to make sure the boss has a radius on it - which is easy.
It's best to ditch the Lucas system if the engine is modified in any way. Some might say even if it isn't. ;-)
Ok - ditched the 14CUX and now running megasquirt and coilpacks, with a wideband. Car still stinks to high heaven, despite a 13-14 on the wideband (which doesn't seem to be very steady). If you rev it up to about 2k it starts popping and running badly.
I'm beggining to wonder if I've mistimed the cam - I took a photo of it at the time, as i noticed a few different marks on the lower sprocket.
Does this look right:
As i'm not convinced its right now.. (hence why i took a photo at the time, as i thought this may come back to haunt me)
Not sure what timing you were going for but I would say that you had it timed 2 degrees retarded, is that what you were after? I think it would be well worth checking the lift at .05" against the timing card for the cam though, if you need a big timing disc for the crank I can drop mine over one evening.
Hi Mike.
Wasn't planning on any adv/retard - just wanted in the correct place. At the time i didn't have the kit to clock it correctly - so took a guess.
The problem is that i didn't know which numbers i was supposed to be using. That lower gear has two rows of numbers and I wasn't sure which to use.
Has anyone seen that style of gear before?
It's been a long time since I did a Rover engine, but pretty sure the inner number goes to the keyway, and the outer number reflects the spot.
So that does look to be either 2deg advanced or retarded.
But 2 degress is certainly not enough to make a noticeable difference. IMO you could easily see 2deg from a new chain to a stretched chain
My own LS timing chain is the same, except because of how the oil pump drive goes on, the inner numbers are worn away.
So you are supposed to align the outer hard stamped "0" with the woodruf key and not have it the 12 oclock position that i roughly have it in?
The inner zero would go to the key. The outer zero would be the 0 alignment spot for the cam gear.
:whs
Well that was my reasoning anyway line the dot with the -2 and the woodruff key with the -2 position = 2 degrees retarded, 0 to the dot and 0 to the key = straight up, though as Stevie says 2 degrees on a rover with no tensioning arrangment as it has would make nor differance in the real world.
I can drop a dial gauge and degree wheel over on Thursday night if it helps??
kiwicar wrote::whs
Cheers mike - i've got all the gear myself now.
Hmm - wonder what the issue is then..
Will check it out anyway though.
kokkolanpoika
Post by kokkolanpoika »
STD timing. If you need more data how to adjust i can take more pick.
Uploaded with ImageShack.us
Timo
thanks timo - much appreciated.
So i'm only 2' out then.
How can 1 "woodruff" key slot equate to 2 degrees?
To my eye each "slot" would be approximately 25 degrees apart.
At 2 to 1 ratio to the cam that would equate to 12.5 degrees out
I'm probably missing something but from the picture I cannot see anything like a 2 degree adjustment
Ian Anderson wrote:How can 1 "woodruff" key slot equate to 2 degrees?
Thanks for that Ian - as I have been thinking the very same thing today and in fact i was thinking it looked more like 20' !!!
The offset is the difference between the keyway position and the gear tooth. There are not equal numbers of keyways as there are teeth
