does it matter where number 1 is as far as where the rotor arm ends up
as you just move the leads around the cap to match it ???
In theory it makes no difference. Although dizzys with an amp on the outside might want that in the best airflow.bodger wrote:Further to this .. maybe a silly question but i have always wondered ..
This 16degr setting is to be set at idle speed, right? 800-1000rpm?softdash3.9 wrote:If you clean up the pulley there should be timing marks.
I run my RR Classic 3.9 on 16 deg BTDC base timing for LPG with vac disconnected.
16 deg is beyond the std timing @ 12 deg, I use a paint marker to mark TDC and the timing marks
Yesjan_rrc39v8 wrote:This 16degr setting is to be set at idle speed, right? 800-1000rpm?softdash3.9 wrote:If you clean up the pulley there should be timing marks.
got to dig out my strobelight. it's been a long time since i used it.
