My engines a 9.35 comp engine, is it worth while getting it skimmed down to raise the compression slightly?
Thanks for the help Guys
Adam
Whats the best way to clean up the casting marks?? Is it best to use a small dremel like tool with polishing mops and grinding paste?kiwicar wrote:Hi
clean up casting marks and blend any sharp edges in the heads
I dont think there is any real problem with them for an engine design that is nearly 50 years old, faults yes, like the strange size/shape they are, especially the oil pump seems to get in the way of any suspension without fail, they are for example a fair bit bigger than the SBFord and not much lighter,I suppose the real problem is the problem of making the engine perform, pound for pound it has to be one of the more expensive engines to tune once you get beyond the basic tuning levels, The popularity of the engine still make used performance parts relativly expensiveAdamSindrey wrote:Excellent![]()
Does the Rover V8 have any achileas heels (or however its spelt) ?
Thanks, Adam
There is a lot of side load through belt tension, jamb your finger in a belt and tell me there isn't any load lol. It would be like cutting out one of your wheel bearings and only using the inside one.AdamSindrey wrote:But is that the only bearing? if there is two which I can imagine there is, one behindthe imperller and one at the end of the nose, then the furthest foreward one, ahead of my cut line isnt needed as there is no load.
