Quality Rockers??
Right had a look at my new after market rockers/ shaft and compared them to my old OE ones:
My measurements: in mm.
After market-
rocker 602154 = 20.62
rocker 602153 = 20.67
shaft 1 = 20.50
shaft 2 = 20.51
Used OE-
rocker HRC 1050 23A = 20.61 horizontal (20.64 vertical)
rocker HRC 1050 24A = 20.62 horizontal (20.65 vertical)
shaft 1 = 20.53 horizontal (20.49 vertical)
shaft 2 = 20.53 horizontal (20.49 vertical)
I will asume there is very little wear measuring the horizontal dimension. You can see the used rockers have worn 0.03, the used shafts 0.04.
The clearance with the rockers 602154 looks reasonable at 0.11 compared to 0.09 for the OE. For rockers 602153 clearance of 0.17 looks too big, nearly twice the OE. I'm going to send these back and get some more.
If you use the vertical dimensions of the OE the clearance goes to 0.15 and 0.16.
Comparing the shafts the AM actually have the oil holes camfered which the OE hasn't.
After market-
shaft 1 = 20.50
shaft 2 = 20.51
Used OE-
Well I have recieved my new rockers, these are branded Britpart OEM. These others were just rapped in old newspaper. These also have date codes cast into them which is nice, shows they are interested in traceability. The finish of the bore is also much finer and the aluminium looks nicer.
They all measure 20.55mm ID which gives a clearance on my 20.51mm shaft of 0.04mm compared to the non branded ones of 0.11 and the worn OE ones of 0.09mm
I don't know if this will even be noticable for noise/ oil pressure. I guess i'll see and maybe curse when it binds as it gets hot due to lack of clearance
Why should you not use steal arms, I heard in the past they are stronger, but by the looks of this thread they should not be used.
Did not see that in this thread at all - what is made clear to me though, is that no matter what the material, alloy or steel there are poor quality parts in both that need to be avoided and care needs to be taken.
Andrew
Andrew
TVRleigh wrote:Why should you not use steal arms, I heard in the past they are stronger, but by the looks of this thread they should not be used.
4.5L V8 Ginetta G27
Should you avoid all steel rockers or just these ones.CastleMGBV8 wrote:V8 Tuner has rockers and shafts which I believe are genuine Rover, approx £120 for the set.
There are some people offering steel rockers which are best avoided.
http://v8tuner.co.uk/category.php?id=32
I believe that the original Federal Mogul rockers were of good quality however they did require a mod to weld up a non required oilway otherwise excess oiling occured.
I do not know if the currently available steel rockers are federal Mogul ones but there ghave been a lot of reports of them being of a poor quality.
I think Steel rockers are only needed if you intend to extend the rev range to 6500+ (according to 'How to power tune Rover V8' book) Apparently the rocker shaft will brake at the end before the rockers do.Should you avoid all steel rockers or just these ones.
As for the quality of steel rockers I couldn't say, my rockers I checked were aluminium.
All I can say is whatever parts you fit just check/ measure them to ensure tollerances are ok.
Since steel is heavier than ally that seems rather odd, increasing the valve train weight with higher rpm sounds like a recipe for disaster to me.SuperV8 wrote:I think Steel rockers are only needed if you intend to extend the rev range to 6500+ (according to 'How to power tune Rover V8' book) Apparently the rocker shaft will brake at the end before the rockers do.
Most folks I know that wanted steel rockers was purely because they had experience of pads falling off.
- topcatcustom
I did buy a set, and I found 1 of very poor quality and had it replaced.CastleMGBV8 wrote:I believe that the original Federal Mogul rockers were of good quality however they did require a mod to weld up a non required oilway otherwise excess oiling occured.
I do not know if the currently available steel rockers are federal Mogul ones but there have been a lot of reports of them being of a poor quality.
I had a problem with the camshaft, so everything got destroyed anyway.
I've since found someone to re-bush my Group A rockers, these are steel, but are much lighter than the V8Tuner ones. plus are adjustable.
