weber 500 problem
russell_ram
Post by russell_ram »
"the Weber carbs, as I use a Carter four barrel (400cfm)"
But of course the Weber is a Carter four barrel (500cfm).
KMCE
Post by KMCE »
Every day an opportunity to learn :)
So is the Weber a re-worked version of the Edelbrock, which in itself is a replica of the Carter, or direct re-work of the Carter?
V8 Heaven
Range Rover: 3.9 Carter AFB, Offenhauser Dual plane manifold, S2 Heads, Fast Road Cam, Vernier Timing Gear, MSD 6A c/w Blaster Coil
Oh.. and an Aston Martin V8 Series 3S
Alley Kat
Post by Alley Kat »
Weber and Edelbrock 4-barrels are identical, just badged differently to suit different markets. The carb is derived from one of the Carters, can't remember which one.
Pocket rocket
Post by Pocket rocket »
Carter AFB (Aluminium Four Barrel) I think
