I built a 289 with 2vCleveland heads years ago, and tbh I think the heads are too big for street use, and are NOT a straight bolt on swap, waterways need drilling and pluging, and the cleveland heads will not take a windsor manifold, this can be got around by fitting ally plates to the heads, plugging and redrilling the the heads to take the inlet manifold, this way you can used any of the off the shelf windsor manifolds, exhausts will have to be custom as well,
or Ive just spotted this, sounds like a good deal,
http://www.nsra.org.uk/newforum/showthread.php?t=16056
engine choice for a mk 3 capri
How about this as a base, add a thick head gasket to drop the CR to about 8.5 to 8.75 to 1 and don't spin your 6-71 too fast and your done!
http://cgi.ebay.co.uk/ford-v8-5-0ltr-sm ... 286.c0.m14
or this if you want to do a bit of work yourself.
http://cgi.ebay.co.uk/Ford-302-cu-in-Sm ... 286.c0.m14
- HairbearTE
- Guru
Why bother with 2V heads or 3V heads when there are ultimate designs available...
http://www.chiheads.com/3v_185cc.php
OK, at this stage the budget is probably blown in bits
- HairbearTE
- Guru
