Intake manifold fitting
TBH i've never used a torque wrench on them - i just pull em up till they feel about right.
Once its been started, i find you can usally nip them up a little more when its warm.
Edit:
I've updated the page with a warning.
Eliot wrote:TBH i've never used a torque wrench on them - i just pull em up till they feel about right.
Edit:
i do the same as :whs
seight
Post by seight »
Should you put any lube on the bolts ?
ta
Mike :?:
sidecar
Post by sidecar »
Eliot wrote:
Edit:
You've made me famous!!! :D
(Seriously, I don't think that you can do anymore than that)
If you are really bored you could test the torque of one of your bolts, I bet its around 20 ftlbs!
Pete
chodjinn
Post by chodjinn »
I just fitted my new valley gasket and manifold last night.
Dunno what i waas doing wrong but i could only get two long bolts in (I'd dropped them when i'd set them out so messed up the order.
Put silicon round the water holes; used thread lock on the bolts and tightened them gradually - all up to 30lbs/ft as stated in the Haynes.
. . . Seems to be ok . . . ??? I hope :?
jrv8
Post by jrv8 »
The installation instructions for the Edelbrock performer inlet manifolds recommend that the bolts are not tightened beyond 25 lbs/ft, and are torqued in a pattern starting in the centre and working outwards. If this is not followed, the manifold is liable to crack.
The standard SU or efi inlet manifold , however, can be pulled down to 30lbs/ft as recommended in the official documents.
Regards
Jim
minorv8
Post by minorv8 »
Been there, done that...
