Phil
What sort of price would that be compared with fitting, say, a late model Chevy 'aloominum' LS motor? Would it be a practical and economical equivalent?daxtojeiro wrote:The 5.5L RV8 based engine from Rob at V8Developments running one of my MS's with wasted spark, TVR heads, hydraulic cam and an ACT triple pluenum produced 374BHP (420lbs of torque iirc) on a known good rolling road. I want one now![]()
Phil
Holy moly! Did he give details of the heads spec? And was it the same 5.5 that was in Practical Performance car racing a maestro of all things?daxtojeiro wrote:The 5.5L RV8 based engine from Rob at V8Developments running one of my MS's with wasted spark, TVR heads, hydraulic cam and an ACT triple pluenum produced 374BHP (420lbs of torque iirc) on a known good rolling road. I want one now![]()
Phil
I have absolutely no idea, I thought it would be as quick as mine as it still has CAT's and that awful TVR exhaust, but its as if someone has bolted a turbo onto it. Rob reckons it will take some boost too, as he says its a very strong lump, so I may go that way in the future when I get used to the power,ihatesissycars wrote:So its got some poke then! How come theres such a difference between a your 5.0 and 5.5? Your engine is standard tvr griff isn't it?
That sounds similar to min mgb 3.5. I got 187 at the fly 220lb/ft, with weber, piper 285 cam and polished ports etc... I went to alwyn kershaw in york. He didn't have the jets and it was running like a pig at the time so maybe should be a bit more no that it runs well. 200 maybe or is that too hopefull.My old V8 in my MGB does about 185 at the fly, about 155 at the wheels with no gas.
