WHAT ARE THEY WORTH ???
I will let you`s know when the time comes. As i say though, I will be running it throughout the year till the end of the race season. If i can run a low 10 with gas and 11.0 without gas it will make it look better
when i put it up for sale.
Was Rover v8 10.7@122mph, 0-60-3.01sec
Now Blown BigBlock Chevy 9.9@134 upto now on low boost.
- desertrover
- Helpful or Confused
Hows this for you olly
And the bottom end inc cam & lifters and timing cover has done less that 1000 miles so as good as new and has had the oil changed about 8 or 9 times..
5ltr Wildcat bottom end with 96mm top hat linners X Bolted Block,
Diamond forged pistons,
Wildcat H Beam rods,
ARP rod through out.
Also just of top of my head !
Holley 650dp
huffaker hi rise inlet manifold
256 solid cam and lifters
intermediete timing cover oil pump (solves oil pressure problems)
Group A rockers and push rods
Headman header exhaust manifolds (Drivers side altered 1" closer to engine for tight spaces)
Dizzy ( Been weilded up for the use with msd)
Holley 650dp
