3.9 won't revv over 4500 rpm
I'm pretty sure it's not lack of travel, as there was no difference between when I had someone push the accelerator for me and me activating the thrrottle at the side of the carb. Anyway, I'll dismount it tomorrow and have a closer look.
What happens when Pinocchio says: "My nose is about to grow!"?
Not sure of the variances on the 500 Kat, but mine will open the secondaries mechanically. Full pedal is fully open on mine.
Not got mine any more, just had it in my head that it was mech at first, up to a point, then vacuum took over. Dunno. Quick google only turned up a basic "both mech and vacuum" statement on here with no detail http://www.v8engines.com/carbs-1.htm
Maybe different variants like you say, or I'm on the wrong drugs ...
All the owner's manual says on that subject is:
There's no mention on how they open, though, or I've overlooked it.The Secondary Throttles (1) begin to open when the Primaries are about 65% open. The Primary and Secondary Throttles arrive at the WOT stop at the same time.
They are mechanical any reference to vac operated is the flap inside which is a kinda counterbalanced flap that open with the amount of airflow.
Depending on the manifold used the throttle linkage can hit the manifold stopping it from opening fully. I know the JWR duel port is effected by this but others might be as well. check that this isn't the case and if it is then either sort it or bend it out the way. If my memory is right its the end with the big hole you would normally connect an auto kick down to that hits and you can simply bend it out the way.
You need to study the link between the throttle shafts. If (as you state) they primaries open fully, then the issue is with the link between the two shafts.
All references to vacuum secondaries is talking about the metal trap door part ABOVE the actual throttle plates.
I have a 600 (same as a 500) on the shelf for photo's if it helps
Here's a clip of it - (warning, its 3.5Mb)
http://homepages.nildram.co.uk/~eliotmez/linkage.avi
I've got some stills, but the video shows what should be happening - i suspect the link bar is missing or bent.
Thanks for the vid, Eliot. That's what my carb does now, too!
The problem was simple: The secondary butterflies hit the manifold, thus they were stuck at only a fraction of opening. We remedied it very easily by drilling the holes that hold the carb in place larger by a millimeter. That way, we could mount the carb a tiny bit more to the front, enabling the butterflies to operate freely and smoothly!
Thanks @ all for helping!
