Pulled the valve cover and checked for movement of the rockers - all tight, no movement. I’m going to do the compression tests again, with full throttle and all the plugs out.
Runs quite with the belt off. Still a tiny wobble on the crankshaft pulley.
I shot a quick video with the cover off.
https://www.dropbox.com/scl/fi/9roiqz1w ... 9lt64&dl=0
New engine problems...
Re: New engine problems...
It's a bit difficult to tell from the video but are the valves for cylinder 1 moving as much as the others?
Cylinder 5 seems to have more movement, I can't really tell for cylinder 3.
Yes you're right not easy to see. #1 doesn't seem to move any slower. I was away this week, but I'll take another look over the weekend.
1978 MGB Roadster
Converting to V8
Converting to V8
