Wish i went to Uxbridge.
- ihatesissycars
- ihatesissycars
- The Original Tom
If theres anything you need and if i got it your welcome to it Ian.
if i had 50k mate i'll be out with demo by now.
- HairbearTE
- Guru
keep us posted mate
Its not looking good, The P5 bottom Pullyey keyway is starting to fret, But it looks like the bottom timing chain sprocket has burst into 3 major parts, with the cam not turning the valves are hanging down on at least a couple cylinders, Taking off the rocker coversI have at least 4 broken Rockers, 3 with the tips sheared off and another brokne thru its bore, so I can recon on 4 bent/broken valves and 3 damaged pistons.
As its Pishing down at the mo, the heads will have to wait till tomorrow, and I noticed a couple of external studs are a bit rusty around the exhaust ports, so they have had a dose of WD40.
I was measuring up the 302 this afternoon. JUST IN CASE
- ihatesissycars
dollar exchange rate at the moment you won't find a better time to go 302 (or 347). I've been buying bits for the chevy build this last week, got 15 % and 10% discount off on line catalog off both supliers without even asking (Iskey, and comp cams) didn't get that last year when I bought the heads and bottom end.
good luck
good luck
