I think so.SimpleSimon wrote:So thats a NO then?unstable load wrote:Lots of 2-pack resins are susceptible to weakening with heat, but it will probably take enough to cook the block and anneal it, so it looks like it's a sharpened screwdriver and a half-brick to chip it out....![]()
Half resin filled
Not sure about Resin fillers. But I tried Moroso block filler on a RV8 test engine and found that despite me doing the filling procedure as per the book.
The filler expanded to the point where it split the ally block both sides around each middle core plug.
The filler, when mixed with water looked just like the floor levelling compound you can buy from builders merchants.
Pel
Pel
Thanks Elliot
That is what I have decided.
See what older blocks come up as I need pre 75 to help on emissions
Car is registered as 2006 so emissions are 2006 or date of engine, whatever is older.Eliot wrote:I doubt that's an issue now that the car is on the road....Ian Anderson wrote:Thanks Elliot
Anyway - anything pre-cat (~1991?) will piss past emissions if it's tuned nicely or injected.
I fancy old school quad Webbers now mention that and emissions in the same breath and most people suck a lot of air through their teeth!
