Did you make a prop then?v8saph wrote:Hows it holding up paul i need it strong enough for real hard launches etcPaul B wrote:I made the prop for my Morris myself, using an SD1 prop and a Sherpa prop. Totally coincidentally they are the exact same size tubing, though one is a cv joint on a UJ. I made a 6" long steel sleeve tube that tapped lightly into both props to line them up and I welded round it, also added a couple of keyhole welds on each tube.v8saph wrote:thanks guys it needs to be as cheap as poss as its just a track toy not a daily drive if it just needs shortning i have a guy that can do it i wil have to way it up when the limp is in
i hope i am able to do this as it would save loads of money
Mines done 4500+ miles so far, lots of 70mph motorway work, quite a few heavy foot starts for fun, and it's still hanging in.
