Bearings break up on track due to low oil pressure
BISH V8
Post by BISH V8 »
Current project
1972 mgb v8 4.6 roadster
BISH V8
Post by BISH V8 »
Current project
BISH V8
Post by BISH V8 »
Current project
BISH V8
Post by BISH V8 »
Current project
BISH V8
Post by BISH V8 »
Current project
BISH V8
Post by BISH V8 »
Current project
BISH V8
Post by BISH V8 »
Current project
BISH V8
Post by BISH V8 »
Current project
BISH V8
Post by BISH V8 »
I just cant understand it, striping down engine why cant I see much damage to the bearings, in the strainer you can see quite a bit of copper and I would say about the same amount has been cleaned from sump, where has it all come from, bearings 3-4 are wore but it is just not enough, the crank has burn marks which can be repaired as it isn't scored, I was expected something with more damage for the amount of copper fillings and the noise the engine made from video..
Any suggestions where its come from
Current project
Presumably a regrind and a new set of shells will sort that out?
BISH V8
Post by BISH V8 »
Yes crank can be reground.
Closer image of bearings 3-4
Current project
SimpleSimon
Post by SimpleSimon »
I can believe that noise and all that copper from those big ends bearings they are in awful shape 8) I would get those journals miked up too, 5 & 6 rod journal dont look healthy from here :?
minorv8
Post by minorv8 »
I have opened my Accusump and it is a piece of cake. You can´t really damage the O-rings unless you are extremely careless. With that much crap I would clean everything, remove the oil gallery plugs etc and double check that it is really 100 % clean.
As for the crank, looks like it needs a regrind.
BISH V8 wrote:Image
Must agree that there seems to be more swarf in there than just two failed big end shells.
Have you checked the cam bearings?
Darkspeed
Post by Darkspeed »
If you have taken those BE's shells down to the backing steel I am not surprised by that amount of material.
4.5L V8 Ginetta G27
