......and the valves may well now be bent.ChrisJC wrote:
I think a compression test will read very low if the valve timing is miles out too.
Hi Chris,ChrisJC wrote:Hmm, that's interesting. How far from TDC is No. 1 (or No. 6 for that matter, it is the same as No. 1) when the valves on no. 6 are 'on the rock', i.e. both equally open?
I don't know that it has to be perfectly at TDC, but in the ballpark is a must.
If it's 1/2 way down the bore, then that is your problem.
New cam,cam wheel and new timing chain all from rimmer bros. I took a great deal of time ensuring that the dots did line up, but the oringinal did have a much clearer,simpler dot than the aftermarket wheel. but now doubt has set in.....DaveEFI wrote:Unless you have faulty parts like cam and wheels, it's near impossible to get the timing out. Assuming you lined the dots up. And has been said, a couple of teeth out or more will result in valves hitting the pistons.
I did have an aftermarket cam and components where the dots wouldn't line up perfectly. Exactly between teeth. If they can't get a simple thing like that right, makes you wonder how they could grind a cam accurately.
For me, that would trigger me to explore this further.R0vers wrote:Hi Chris,ChrisJC wrote:Hmm, that's interesting. How far from TDC is No. 1 (or No. 6 for that matter, it is the same as No. 1) when the valves on no. 6 are 'on the rock', i.e. both equally open?
No1 seemed to be between about 1/4 down the bore.so yes you reckon that's where the prob may lie... Not quite sure where I go from here?
bit of a chicken and egg situation - the only trick i know is some oil down the bores - but are there any other ways to up the compression to initially get it going?DaveEFI wrote:I'm wondering if the fact it is a re-built engine with honed bores and new rings which hasn't been run at all and stood for while has a bearing? IMHO, that won't get full compression until the rings bed in?
Many years ago I did a similar thing to an MGB engine and took it from London to Aberdeen to fit it. And it simply wouldn't start. Checked all the usual things several times. We had to move the car to another storage place, and while it was on tow, I tried a bump start. And it started near instantly.
