Dizzy as cam sensor
DaveEFI wrote: I've played with ATS correction at high temps - but with little success.
In theory you would lean mixtures as air temp rises according to some dudes gas laws or something.
I've yet to find an engine that will actually happily run with these settings though. Although I've never used a remote mounted air temp sensor ( ie more akin to an ambient sensor ), all have been installed closer to the engine within boost pipes
Either leave most values from 30degC or higher at zero compensation, or sometimes even add a little fuel.
Once closed loop correction kicks in, it should take care of anything if you wish to target specific AFR's
Cobratone
Is a Spanner
Post by Cobratone »
I noticed in the early part of the video before the reset that the pulsewidth was lower and also the ego correction was at 112%? Could either of those things be causing your problem rather than injector timing??
Cobratone wrote:I noticed in the early part of the video before the reset that the pulsewidth was lower and also the ego correction was at 112%? Could either of those things be causing your problem rather than injector timing??
+10% at idle, yet even when wideband comes online IJPW's dont seem to change as if close loop isnt actually active.
I can only presume when the dial is red those corrections are not actually being applied ?
Either way, it doesnt look like they are being applied even when screen isnt red
Either way, the main problem there is the AFR reading and behaviour on screen is not correct.
I'm assuming MS incorporates a baseline correction for rising air temperature as seen by the ATS. You can then trim that in a table.
SimpleSimon
Post by SimpleSimon »
That look like a firmware glitch or another hardware issue IMO absolutely no way would that RV8 idle at those lean AFR's as said already no way :(
