Rear end help...
Have you had a look on eurodragster recently, http://www.eurodragster.com/classifieds ... category=9 there is a lot that should be of interest to you on there at the moment.
chodjinn
Post by chodjinn »
SD1 axels are pretty easy to convert to discs from drums, I'm running a pair of Sierra Cosworth calipers on the rear with built in cable handbrake - they are available off most sierras/granadas.
I would not recommend you plan to start with a RV8 then Chevy, stick to one and go with it, for ease and expense reasons if nothing else!
minorv8
Post by minorv8 »
If you seriously want that 500 hp then forget the Rover and go directly to SBC. I would but invested too much in Rover parts. There is no market for performance Rover parts where I live so I am pretty much committed to sticking with RV8.
chodjinn wrote:SD1 axels are pretty easy to convert to discs from drums, I'm running a pair of Sierra Cosworth calipers on the rear with built in cable handbrake - they are available off most sierras/granadas.
What discs did you use? Presumably vented if for Cosworth callipers?
Only 4wd cossies had vented rear discs.
Just use whatever discs fit best.
stevieturbo wrote:Only 4wd cossies had vented rear discs.
Trouble is there are millions out there. Most of which won't clear the SD1 hub.
I say it again. . . if you are going for 500 bhp then have a look on eurodragster, there is now a 9" ford at a very good price, it would cost about £700 to get it shortened and a diff put in it but that is still very cheep for what is there, and you would get back £100 for the shafts and £75 for the spool, flipin' bargin!
Adapt and overcome ;)
I have done. Just wondered what others had used. Many seem to use 800 discs which are solid and require the half shaft flange machining as well as new stud etc holes.
Ive no idea what an SD1 hub looks like, so cant comment.
But it's a live axle, most are very similar. It really cant be that difficult to select a disc that will work.
stevieturbo wrote:Ive no idea what an SD1 hub looks like, so cant comment.
I'm sure it's easy enough if you have a machine shop at your disposal.
My requirements were being able to change back to standard if needed, and as little disc modification as possible. Discs don't last forever.
I certainly dont have a machine shop at my disposal. In fact getting things machined reliably here is a nightmare !
But some planning and thought goes a long way into making most things happen.
Quite. However, your replies do sound rather like Clarkson saying "how difficult can it be" :D
TBH fitting rear discs is pretty easy. Apart from getting a Wilwood bell blank machined, which I couldnt do myself.
The only other tools I needed to fit discs to my axle was, drill and angle grinder.
Certainly nothing there beyond the reach of most DIY enthusiasts.
So really...it isnt that difficult.
The most awkward part I can think of is sourcing a handbrake cable of suitable length.
A Sierra one was as close as it needed to be for mine.
Ah. Most SD1 rear disc conversions use modified stock discs - not racing parts. To keep costs sort of half reasonable. When I looked at it, racing discs and adaptors would have cost about £400 including the necessary machining, before even thinking about callipers and brackets.
