help me round a few bends pls.
- ihatesissycars
That wouldnt work, not with the RR stuff as its all far too big. The engine would also have to go about good bit further back. One of the members on here looked into fitting a diff to the bottom of a rover but found it wasnt a good option because of the block design.JC. wrote:Didnt the car start life as 4WD?
Is it possible to retain the 4wd system if you use a range rover gearbox + transfer case?
- scoobyv8
as above, big NO NO!katanaman wrote:That wouldnt work, not with the RR stuff as its all far too big. The engine would also have to go about good bit further back. One of the members on here looked into fitting a diff to the bottom of a rover but found it wasnt a good option because of the block design.JC. wrote:Didnt the car start life as 4WD?
my car started out as a 1.6 front wheel drive only. i did consider fitting the running gear from a 4x4 and make an adaptor ring to mate the v8 with the subaru box. but it would mean the engine sitting well out infront af the front axle. see the pics on my old page link is on page 1 of this thread just now my choice of final drive is just the subarus rear axle setup. i may need to change or upgrade this later if it cant handle a standard ish 3.5 but thats a different story.
plus rwd is mutch better, no power lost thru the tranny, and more fun in the corners - steer from the rear, if you know what i mean
George
The refinement of modern day comfort, and the prestige of a rover V8! In the making.
plastic orange
- ihatesissycars
Just quick note about the serp timng cover or more specifically the oil pump. Whilst cranking my engine over last night (it turns over at about 190rpm) the oil pressure guage was up halfway, just on cranking! i'm guessing thats about 40psi and other than lubing it up with some heavy gear oil when i put it together i did nothing to help it prime up so so far very good!
- scoobyv8
just what i need. but i dont have the funds just now. maybe some1 from here might be intrested
George
http://cgi.ebay.co.uk/SERPENTINE-KIT-V8 ... dZViewItem
George
-JC.
