Rover V8 Engine Numbers Updated:
- ged
You may have missed this.Mickxjr wrote:Could you please identify this engine for me, ie size 3.5 or 3.9 Rover, Landy, Range rover, thanks in anticipation. 30A0003358.
http://www.v8forum.co.uk/engineno2.htm
Regards Ged.
paultwymanuk
I have an early RV8 in a Triumph Stag.
I have tried to workout where this particular engine is from without success. The engine number is 56822635C and it is stamped on the rear of the block on a flat area of the bell housing (rather than the side, under the head). The comp ratio of 10.5:1 is stamped next to the engine number.
Any of you chaps got any ideas.
engine number
Hi all. Newbie on this forum.
Can anyone give me any info on my engine. The engine number is 84015228. Thanx
Re: engine number
Rover P5B IIRC. 10.5:1 cr. There should be a suffix letter at the end of the numbers.asam_x wrote:The engine number is 84015228. Thanx
engine numbers
Will look again. Thanx
engine number
Just checked,again. There is a capital letter c about an inch away at the end of the numbers, and above.
engine number
Dont know what that means, but thanx Harvey
