Megasquirt 2 cooling fan control
Anyone know what current the cooling fan output on the MS2 can handle, I know it can only operate a relay but will it handle 350ma ?
Range Rover 630R or otherwise known as the Money Pit
MS2 with switch MAPS for LPG
Techedge Wideband Sensor
Since there's not a dedicated cooling fan relay driver (as there is for the fuel pump), do you know how it's been done? If you're not using the Fidle valve driver for that purpose, that would be the norm to use for a fan.
The pump and Fidle relay drivers are identical, and can handle 1 amo if a ZTX 450 is used, or 800mA if a 2n2222.
But if a driver has been added from a spare port, you'd perhaps have to check just how it's been done. I'd expect that mod from a decent supplier to use a 2n2222 - so you should be ok.
Is it to drive two relays in parallel?
