Clutch advice
Clutch advice
Hi all
I have a land rover 90 which had a 3.5 V8 on a lt 85 gearbox and now has a 4.2. I do a bit of off roading so it does get a bit of ragging on steep slopes etc. The clutch and flywheel are off the 3.5,
The problem I am having is the last few times out the clutch has been smelling quite bad and today it started to slip. Left to cool down and drove home fine.
Looking at clutches I see there is clutch for 3.5 and 3.9/4.2 just wondered what the difference is and will a 4.2 clutch fit my 3.5 fly wheel?
Thanks Mick
Thanks Mick
Rover 3500 SD1 cars had a 9.5" clutch and later larger engines had a 10.5" clutch. The Later flywheel is thicker and heavier and will only accept a 10.5" clutch and earlier flywheels will only accept a 9.5" clutch.texpis wrote:Anyone ?
You need to establish which flywheel you are using at the moment.
Regards Denis
Anyone used one of these
http://www.clutch-specialists.co.uk/sta ... 369437.htm
Do you think it will suffice or is it it a it borderline. Problem with range rover flywheels are like hens teeth most of them were auto boxes
Mick
Mick
- Rossco
- Moderator Gold
I have a new and unused one which I'm not using. It will take a bit of time to get to it though.texpis wrote:Anyone used one of these
Mick
