Compression testing
4.6_crossbolt
Compression testing
Post by 4.6_crossbolt »
While hunting for the cause of a non-firing cylinder on my Scimitar's Rover V8 (prefix 11A - cr 9.35:1), I did a set of dry compression tests - the results of all eight were between 140-150 psi.
Is that figure reasonable? I know a difference of about 10 psi is nothing to worry about, but I was curious as to what figure I should expect.
Incidentally, the non-firing turned out to be a sooted-up plug which occurred during setting up a four SU installation on a Boxer manifold - a somewhat tedious and complex procedure.
2000 (X) Range Rover 4.6 Vogue + LPG
1985 (B) Rover SD1 4.6, T5, LSD, SP+MegaJolt
1972 (K) Reliant Scimitar SE5A 3.5 V8 + quad SU's
SimpleSimon
Post by SimpleSimon »
They are similar to what I got with a serp 3.9 with the same CR with a spikey cam I backed this up with a leak down test which gave very good results for a high mileage RV8 8-)
I tend to concern myself with all readings being similar, rather than what the readings actually are.
4.6_crossbolt
Thanks for the information - I have no idea of the engine's history, so can only guess at the mileage, but I imagine it's fairly high. The results seem reasonably encouraging that I'm not facing a rebuild just yet.
SimpleSimon
ChrisJC wrote:I tend to concern myself with all readings being similar, rather than what the readings actually are.
