Just wanted to tell you all that we have developed a new toy for you all.
This controls the steering assistance given by the Corsa B or C ECU depending on the Vehicle Speed.
The Corsa EPS Speed Unit can convert your vehicles existing speed pulses into a signal that the Corsa (B or C) ECU expects to see. This gives the EPS ECU the ability to run different assistant levels depending on the vehicle speed:
<15MPH High Power Assistance
15-35MPH Medium Power Assistance
>35MPH Low Power Assistance
To do this the Speed Unit needs a 5 to 12V pulse from your speed sensor, so it would need either a proximity sensor, or a hall sensor that detects a bolt, toothed wheel, etc. If you have a VR sensor (abs style) then this needs converting to a 12V pulse before it can feed the Torque Controller Unit.
For more details see here:
http://www.extraefi.co.uk/CorsaPSA.html
thanks
Phil
NEW Product - Corsa PSA Speed Related Controller
- daxtojeiro
- Forum Sponsor
