I am slowly getting there with the Moss but I am having trouble with the cooling system.
I am after advise and I have my own theory and will explain and show pics
The rad is not a V8 one, no idea what its from but it seemed large enough so I built things around this one. The hose outlets have to go forward for space reasons but don't think this is the issue.
The issue is the filler cap is lower than the thermostat and that hose as per pic. I can obviously take off that hose and fill from there which I have done.
Problems are that the engine doesn't circulate the water at the right time. the engine will get very hot, rad and pipes remain cold. I then have to turn off the engine before it overheats. The fans don't cut in as the temp sensor has cold water sitting there and of course the rad is cold anyway so the fans would not have an effect on the engine water temp !
I then take the hose off, release the pressure and the thermostat is open so there should be flow (think the water level too low or air block) I can fill it up with some water again, re attach and start the engine, eventually after a few goes at this the water starts circulating and the rad gets warm, fans kick in etc.
Next problem is the rad doesn't seem man enough to keep the engine cool, or the fins are too blocked to allow enough air flow through (they are push fans) I didn't notice that the fins were a little crapped up but can't shift some of it.
I just think I need a better rad and maybe fit a filler in the top hose at the highest point so I can bleed out any air ?
Any suggestions welcomed.
Stu[/img]
