can 4.6 block be rebored?
I have a 4.6 engine that I am rebuilding to put in my race car tow vehicle (LDV van). We have measured the block, and found it has too much wear to hone and re- ring. This means either a rebore to first oversize, or a new set of liners and back to std size. As it is on the std bore this would mean finding a set of +.020" pistons and rings (these seem rather scarce?) and boring to this oversize. There was no evidence of a cracked block before. Won't be looking for big hp, (250hp max, but with good torque and I will be running it much cooler than in the RR (around 80°C) so that might help things too. I have been told overboring might weaken the liner, as it is already very thin.
I really don't want to spend a lot of money putting top hat liners in if I can avoid it. So my question is, would going +0.020" be too risky in one of these engines, or am I safe?
Conrad
Conrad
thanks for the replies guys, I will probably go with Real Steel, and get one of their camshaft kits while I am at it.
I do understand why LR do not recommend reboring, and know it is a risk, but am prepared to give it a crack (bad choice of words I suppose!)
Does anyone know the volume of the dish in the 4.0 piston, and the volume of the dish in the 4.6 piston? I know the 4.0 is less and will bump the CR up, but are we talking 10:1, 11:1 or what? Initially I will run on petrol (96 octane) but may possibly fit LPG in the future, so a higher CR will certainly help there. But I don't want to go too high and make it unusable on pump gas.
cheers Conrad
cheers Conrad
I remember seeing a Volkswagen VR6 engine in bits and pieces at local engine shop a few years back. It was worn and needed a rebore but there were no OEM or aftermarket oversize pistons available. Maybe factories calculate that people buy new cars after a few years so there is simply no need for engine rebuild especially if the body itself slowly corrodes away. Basically hte engine lasts the lifetime of the car itself.Land Rover do not recommend reboring the block. This is why there are no genuine parts oversize pistons.
awesome, just what I was looking for!minorv8 wrote:4 litre piston dish is 13,2 cc and 4,6 litre piston is 22,3 cc.
Piston swap would bring the CR up about one whole point i.e. from 9,35 to 10,3. Most likely a bit less but can´t remember exactly.
by my calcs. that will give a CR of 10.66:1 when 4.0 piston is fitted to 4.6 engine. Might be a touch high for my requirements?
yeah that would sound about right. The 4.6 engine I got had covered 170,000kms and was bascially worn out. The RR that it came out of had so many faults that it was not worth repairing, so fair to say that vehicle had reached its "use by" date. By comparison, the 2001 Mondeo 2.0 that I sold the other day had just clicked over 300,000kms, and was going as strong as the day I bought it 8 years ago.minorv8 wrote:I remember seeing a Volkswagen VR6 engine in bits and pieces at local engine shop a few years back. It was worn and needed a rebore but there were no OEM or aftermarket oversize pistons available. Maybe factories calculate that people buy new cars after a few years so there is simply no need for engine rebuild especially if the body itself slowly corrodes away. Basically hte engine lasts the lifetime of the car itself.Land Rover do not recommend reboring the block. This is why there are no genuine parts oversize pistons.
cheers Conrad
- topcatcustom
The liners are the same, the cracking is a result of the core shift when the block is cast, the larger journal blocks are more prone to core shift for whatever region, we run Chevy 305 pistons at 36 thou overbore so +20 should be no problem. The iron liner is not the weak point. It's the aluminium behind it.
Alan
Alan
Hi Alan.bigaldart wrote:The liners are the same, the cracking is a result of the core shift when the block is cast, the larger journal blocks are more prone to core shift for whatever region, we run Chevy 305 pistons at 36 thou overbore so +20 should be no problem. The iron liner is not the weak point. It's the aluminium behind it.
Alan
Are you using Chevvy 305 pistons on a std 4.6 crank?
thanks Mark
Mark
