Vitesse / Discovery efi Plenum clearance ?
Camo
Post by Camo »
Hi Folks,
I have been looking at various carb options for my V8 Moss regarding the bonnet and how much of a bulge / scoop I will need.
I obviously want the lowest I can go but will be buying secondhand at this stage in my life :D
I have ruled out Twin SU type, I have a Holley 390 on there currently but feel the EFi set up from the Rover Vitesse / Discovery 3.9 would be lower.
Anyone have the height from the top of the rover cover to the plenum top measurement to hand ?
Thanks,
Stu
The injection setup is slightly higher than either the SUs or Solex fitted to the SD1.
SimpleSimon
Post by SimpleSimon »
If its a Lucas Hotwire system your using then 16cm approx from top of rocker cover to highest point of plenum top :D
Camo
Post by Camo »
Thanks guys, looks like its the Holley then...
Stu
