BMW 4.4ltr V8 into E36 Saloon..!
E34 V8 5speed is the same as a e36 M3 3.0ltr except for the front housing which includes the bell housing, I cross referenced all the part numbers, every thing except that casing are the same and I think it's only about £150ish to by, I was about go this route when I found the one.... and 400 mile round trip to get it......... It cost me more than my engine....!!!!LOL..
I am guessing that no response = a no?Iain wrote:Would you be willing to lend it or get a pump modified for me?BMWE36V8 wrote:I agree Chris, the rover v8 was and still is an excellent engine and very light..!! Had one in a cortina MK5 and MK3 capri..
I am in the throws of fitting individual throttle bodies on her, should give it a bit more.... and as for the oil pump, I have the one and only jig for holding everything inline for welding the extension pieces in place.....
+1 for that oil pump mod. I was thinking of going the n62 way, and just getting the pump shaft machined, but yours is a tested and proven design (you also answer questions
) Sadly, after 140000 miles, the underside of my car is looking rather sorry for itself, so everything that can come of, is getting replaced or reconditioned, and any reinforcing kits welded on, then the engine swap
Hi,BMWE36V8 wrote:Hi Iain,
Sorry for the delay, but not a no, I have spoke to my mate, as he will have to make the spacer blocks to go into the pump and he also makes a new oil pump shaft, he will let me know what sort of cost that will be involved and I will let you know...
Steve.
I believe that with enough publicity on BMW forums you may want to look into starting a group buy.
My two cents.
- Helpful or Confused
