Which inlet/induction will work with Wilcat heads
leylandracer
Post by leylandracer »
As the subject, Which intake set-up will work with Wildcat heads? Do you think the following would fit/work?
JE Developments crossover inlet? (I did ask JE: None of the std Rover inlet manifolds will fit on Widcat heads unless you
have some adaptors.
If the standard inet fits then my crossover inlet will fit
ACT twin/Tripple CF Plenums?
Cheers Steve
spend
Post by spend »
Anything with the adapters, otherwise only Wildcat stuff, the answer was in your post already????
The heads have a completely different bolt pattern and angle for the inlets(if you look closely) so you need adapters if you want to convert to Rover stuff.
leylandracer
spend wrote:Anything with the adapters, otherwise only Wildcat stuff, the answer was in your post already????
I asked John Eales if his crossover inlet would fit (With mods) & i got a deffo NO :) Any idea what these are (TriumphRover spares) they look similar to his?
Really limited with the Marcos (Meaning what will fit/work) suppose theres no point putting somthing on which wont flow with the wildcat heads
JE X over
