Hi my carbs are overfueling alot and need balancing.
Is this easy to do or dose anyone know a person or company in surrey that could do it?
cheers
bailey
Carb balancing
'Balancing' is usually the term for making sure two or more carbs are synchronised - ie work equally.
If the fuelling is wrong they need tuning (maybe balancing too).
As regards how easy a job this is depends on whether the engine and carbs are standard. And indeed what make the carbs are.
Re: Carb balancing
Explain 'overfuelling' ?. Are they flooding with fuel overflowing the bowls?, or is the engine just running rich?Bailey wrote:Hi my carbs are overfueling alot and need balancing.
cheers
bailey
If it's the former, check the float/needle assembly. If the latter, it could be a number of things.
Lotus Elite 4.6 Spydersport 'Donington' conversion
