Crazy wrote:I hadn't realized they were stage 1 heads, I was under the impression they had been modified / adjusted for tuning but the way they've been described on the web made them sound more involved than a stage 1 head.
One mans stage I is another mans stage III !!
If you want to save a few quid you could pocket port the heads just behind the valves. Basically where the valve insert meets the aluminum track the 'join' is usually quite bad. If you smooth out this area alone you must be able to free up a few BHP!
The bad news is that the inserts are ROCK HARD, you need to use tungsten carbide burrs in a dremel (or somehing similar). The crappy bits of sandstone on a stick from B&Q won't even leave a mark before they turn to dust!
Aximinster Tools does 3.2mm bull nose burrs that will fit a dremel, you would still need about 8 of them, keep them cool when using them by dipping them in white spirit every couple of seconds.
Don't get me wrong, this home porting will not be as good as a Pro job but it's better than nothing and much cheaper!
