BMW V8
Will Reeve
- Getting There
healeyneil
my 540 had a rattle for the first few seconds of startup - never worried me. Unless of course yours is taking longer to sort itself out.Will Reeve wrote:all modern BMW speedo work from the ABS system (rear left wheel sensor usually!).
I would go pre Vanos M62 (the M62 not the M62TU). I have a M62TU with a noisy vanos on cold starts which is going to cost 500quid in parts to quieten down and the timing procedure looks a mare!
Problem is O rings in the vanos unit harden and loose their seal. BMW want to sell you a new unit complete at many squids. But you can replace just the o rings and teflon seals. Labour intensive but not costly in BMW terms.Eliot wrote:my 540 had a rattle for the first few seconds of startup - never worried me. Unless of course yours is taking longer to sort itself out.Will Reeve wrote:all modern BMW speedo work from the ABS system (rear left wheel sensor usually!).
When the seals fail, you get a poor idle and bottom end.
If you gave me the choice I would take the lexus unit, bit of hassel finding a toyota manual box, but get the right one I am pretty sure it is just a bolt up job. The lexus has more tuning stuff at prices you can afford, more amature tuners tuning them, designed to run well over 250K miles on just basic servicing and well under stressed in basic spec.
Will Reeve
- Getting There
healeyneil
Will Reeve
- Getting There
