TR7 V8 conversion heater matrix hose
Will Reeve
Post by Will Reeve »
I am after a replacement hose for my TR7 V8 conversion, one hose supplied by Rimmer just about matches the one off the car, the other one is miles out.
I guess there are 100's of these conversion around, anyone had hose part numbers?
Also, does it matter which way the water flows through the heater matrix? One assumes not.
kstrutt1
Post by kstrutt1 »
It does matter which way the water flows, the heater only works correctly if the feed is too the bottom pipe.
I can't help you with hose part numbers, mine has a LPG conversion and I have just used hose off the roll.
Kevin S
Return to “Cooling Area”
