5 speed or 4 speed for track ??
Managed to locate a late model low mileage SD1 Vittess gearbox with flywheel etc..
Will this be ok for my track V8 with a 3.3 salisbury diff please.
Think I'll google the Vitess and find the diff ratio like I should have done first
Hybrid Kit Car - which could go faster but - wife has a very tight purse
That combination should be fine, depending on wheel and tyre size, let me know what you intend using and I can work out the speed range through the gears.burble wrote:Managed to locate a late model low mileage SD1 Vittess gearbox with flywheel etc..
Think I'll google the Vitess and find the diff ratio like I should have done first![]()
Ratio for Vitesse was 3.08 if i remember correctly but this would give around a theoretical 170 MPH in 5th!
Just worked out with 3.3 ratio and 195/65 x 15 tyre speed in gears at 6000 RPM as follows
1st 41 2nd 65 3rd 97 4th 135 5th 170 MPH which is quite a nice spread of gear speeds 5th would be useful at Snetterton with the long straight.
Kevin
Thanks for that very useful information, seems my diff is 3.2 to 1.CastleMGBV8 wrote:That combination should be fine, depending on wheel and tyre size, let me know what you intend using and I can work out the speed range through the gears.burble wrote:Managed to locate a late model low mileage SD1 Vittess gearbox with flywheel etc..
Kevin
Looks like I'll be using just 4 gears most of the time as I will be at Oulton park or Anglesy tracks.
Anglesy will be third I think. Depends of course on how well the car goes but with about 180 bhp ( not sure yet ) and 700 kilos it should be reasonably quick.
Wheels are 14 inch with high profile tryes for now but will be using 15s on low profiles when I can afford some Minilites.
Still waiting for the gearbox, it will be here in a few days, the job is waiting as I cant weld engine mounts on the car until I can line the transmission up.
hey ho
