I am new to this site so here goes.
I have just Purchased an Opel manta with a P6 v8 fitted with thick head gaskets
The car has had a ford 9" diff fitted and has a nice set of Image LAMBO rims fitted so the car should handle the power ok.
The chap i got it of had a Wade RO34 supercharger mocked up on it
All that's needed to finish is a belt and tensioner.
I have got a landrover 101 engine that has had a full army rebuild and is running very low compresion pistons its also got double valve springs fitted and i have done a bit of porting and flowing on the heads.
I recon this would be a better bet than the p6 with thicker head gasskets?
My plan is to get the car mot'ed with the p6 engine running a edelbrok manifold and holley390 then rip the engine out pop the old 101 in there fitted with the right cam for the job and the p6 timing case.
What do you think?
Also would i have to do any thing with the timing so it dident advance to much at higher revs? change the dissy waights?
Would this setup be ok to run with the holley 390 vac secondery?
Now i also have a NOS cheater kit i recon this may finish of a little 3.5 rover already fitted with a blower? may be some forged pistons?
I have found a post from the old owner of the car it seems he was having problems getting a tensioner for the blower. I am happy to make one up and have a go
Sorry for all the questions and the rubbish spelling.
Many thanks
Derek
