oil pickup
- Getting There
oil pickup
putting my engine together and on the sd1 oil pickup there is a braket on it, it is about 2" away from the bottom of the block, there is a hole in the main bearing cap for it to bolt to, but i am not sure what is used, can anyone help. i hope my explenation is clear.
Re: oil pickup
poo slinger wrote:putting my engine together and on the sd1 oil pickup there is a braket on it, it is about 2" away from the bottom of the block, there is a hole in the main bearing cap for it to bolt to, but i am not sure what is used, can anyone help. i hope my explenation is clear.
It's there to help support the pickup. I must admit that I've not used it on my 3.5/4.6 hybrid lump!
- Getting There
- ged
Hi Ross,
The stud Part No 252517 £0.69 at Rimmers but the others(heavy washer & spacer tube) are NLA. Unfortunately without stripping an engine I can't tell you the sizes. I'm not promising anything but I have a large box of engine bolts in the garage so tomorrow morning I'll see what I can find.
Regards Ged.
Regards Ged.
- Getting There
