35 Dm8 connections
Wee_chris
35 Dm8 connections
Post by Wee_chris »
its been a while since last on the forum as had to put V8 project on hold for a bit, but now I've got started again and plan to try and have car on the road by spring next year. I know it sounds like a long time but got a mini to finish restoring and just got my hands on 1972 Lotus Elan +2 drophead that needs a wee bit fettling, also going away for a couple of months at the end of the year does not help.
Hopefully this is an easy one for some of you.
I have a 35dm distributor on my rover V8, its the one with the amplifier connect to side of the distributor. there are two terminals on the amplifier I need to know what one connects where.
Not sure how to describe layout but hopefully a vertical stroke and a hyphen will demonstrate layout
The vertical stroke one is right angle to the cap
Chris
It's taken longer than I thought !!
Sadly I'm 6000 miles from my van at the moment so I can't check. However this question has been asked on the forum before, so the answer ought to be lurking somewhere......
Wee_chris
Post by Wee_chris »
Thanks Chris.
I had a hunt round but could not find anything.
Called JV8 today and as usual he gave the answer.
Chris
Pocket rocket
Post by Pocket rocket »
Wee_chris wrote: Called JV8 today and as usual he gave the answer.
Chris
Which was? ...
Wee_chris
Post by Wee_chris »
The connectors are positioned like a the letter T the connector which is the top bar is connected to the negative of the coil and the other is connected to the positive of the coil.
Pocket rocket
