Alternator wiring problem
V8 RX-7
Post by V8 RX-7 »
Having trouble wiring my lucas alternator to charge through a rally cut off switch. it has three terminals 2 threaded, one towards the centre and one at the edge, and 1 spade connector can anyone tell me which is the charging post and what are the other 2 for, it is not running any electrics besides bare essentials to run engine, no lights etc.
si
Gotta pic?
V8 RX-7
Post by V8 RX-7 »
hopefully should showImage[/img]
si
Is there any lettering near the connections - I can't make any out?
V8 RX-7
Post by V8 RX-7 »
hi chris the only lettering i can make out is a 0 or zero between the top connector with the nut on and the spade connectot, there is a dash or - next to the lower threaded connector but not sure if it is just a floor in plastic or not cheers
si
Ah, well in that case I'm not sure!
I would go for the larger one being the BAT+
Hopefully somebody else will recognise the pic for the Charge light.
bodger
Post by bodger »
if you know what it's off have a look here :
http://www2.qha.com/q-pid/QPID.aspx?user_id=&session=
tells you the termial config in the specs
