RV8 in my Stag - need to modify the carbs
The factory MGB V8 inlet manifold will take a pair of HIF6's and give you the clearance you need. But this puts the carbs at the back of the engine over the heater valve connection. And they are quite rare!!
I recently sold a manifold to take a single Weber twin choke for many many pounds!!
russ spake
russ spake
I seem to remember a webber 45/48 adaptor for a MGB which bolted onto a Holley manifold and faced the carb backwards towards the bulkhead, Think it was a race series mod so a more tunable/less restrictive carb could be used, but still was still classified as having a pair of carbs
THE SMOKING GNU
Ian,
That I believe was the costello conversion manifold that Perry referred to and probably very hard to find these days.
Another cheaper solution I have seen done is to have a pair of manifold adaptors made which bolt onto the standard rover pent roof manifold and curve back to place the SU's in a similar position to the factory MGBV8.
The cheapest solution has got to be, modifying the SU dashpots or if performance is not an issue swap in a pair of rebuilt Strombergs which I believe Stags had as standard fitment.
