My land rover is running well, the temp is right and everything is sweet. Before changing my carbs for rebuilt ones I needed chocke in the morning to get her to start.. However now I no longer need choke and she fires up on the first turn and will idle happilly after a little rev or two..
I assuemd the carbs were set too rich as a cold engine shouldn't really start that well im sure. But after checking the mixture (using the lift pins) everything seems fine. Is it just a good starter or am I missing something?
Rebuilt 3.5 new rings, bearings, valves so on and so on
