EDIS 8 + GEMS
EDIS 8 + GEMS
Does anybody know if EDIS 8 can be used with the GEMS flywheel sensor and coil packs?
Thanks,
Thanks,
Depends what you want to put in between the sensor and EDIS8. The EDIS8 requires some intelligence source to tell it when to fire and how much to advance or retard. In a GEMS system this comes from the engine ECU. In it's original innstallation again the EDIS is instructed by the engine ECU. EDIS8 on LR in the UK is normally driven by MS or equivalent.
As far as I understand EDIS8 simply rotates the coil firing pulse through the different coils and advances or retards the pulse according to instructions recieved.
What ate you trying to achieve?
jw
jw
I plan to use MegaJolt + EDIS 8 on my latest build.
I hope to use the stock Crank sensor and GEMS coilpacks.
If not, I can fall back to the aftermarket sensor + coilpacks, but it would be nice to stick with at least the crank sensor.
I have everything now to try it anyway, so I'll be finding out shortly!
