An example..........Capri fitted with a 4-71 on a RV8
.........................You don't need a Periscope to see straight ahead
You can see everything perfect whats in front of you and next of you on the right side (
in my case the opposite side...
as I drive on the other side of the road)
Every thing else...well .....what you don't see..ehhh...what you don't miss...
Should warn you for the rain, be shure you'll have the right key next to your chair to turn the scoop backwards when it starts to rain.
It will deffo catch too much water causing the engine to stall. I found out the hard way
Without the foam/mesh filter the blower will breath much easyer as I found out on the dyno. Just use a good round K&N style filter.
