how to flare ali rad pipes
im using 32mm OD 1.6mm wall ali pipe to run my rad water down,
done anyone know of any tool which will flare the ends to make the hoses fit better?
i have been pointed in the direction of a "crox tool" but looks like they are just for plumbing pipe.
Ralph
Ralph
Ralph
Drill a number of holes arounfd the pipe about a cm in from the end
Pip rivet through the pipe
Push rubber hose over the pipe and rivets
Fit Jubilee clip - because of the rivits it can never move!
Simple and does not need the purchase of tools.
- Rossco
- Moderator Gold
Suppose if you can stand the price then this would be a good investment
http://www.frost.co.uk/item_Detail.asp? ... at=Forming
Rossco wrote:Suppose if you can stand the price then this would be a good investment
just the ticket but not at that price! now i know they exist i will ask round see if anyone round here has one.
Ralph
I was going to make some of these:
http://www.v6z24.com/jbodyforum/my-wint ... rt,30.html
Because my pipes were blowing off, but I replaced all the clamps with Quality Mikalor clamps and the problem went away. (Consider that the 3" ones need a 13mm socket to tighten up - they are meaty)
pic:
http://www.mez.co.uk/dcam/DSCF3268.JPG
pic:
Mikalor clamps solve a lot of problems dont they Eliot?
I always clean the pipe and the hose with Alcohol or petrol to make sure they are clean and dry before clamping. I've never had a hose blow off or leak.
