distributor question
holley
Post by holley »
Hi Guys, I found a listing on ebay stating
NEW 3.9 V8 Lucas type 35D Distributor with 3 pin Ignition module comes complete
Fits ALL Land Rover 3.9 engines and TVR, Morgan
Will fit some 3.5 engines but a two pin converter wire is needed,
I have a tvr engine which is the 3.5, would this distributor be ok to use ?
Cheers Guys
Holley
blz6662
dizzy compatibility
Post by blz6662 »
Hi Holley, if that's the RPI one - I've bought it earlier today (they have more don't worry). I have that model fitted in my 88 range rover already, so should be OK. I bought the new one for my other project which is a series 2a hybrid with 3.9 Morgan V8 fitted - this has the same front cover as my rangie so I'll let you know how I get on.
Baden :wink:
Although they will physically fit, you need to be aware of a few subtle differences:
- Pins on amplifier (2 or 3)
- Ignition curve
- Location of vac advance unit with reference to amplifier (see pic below)
holley
Post by holley »
Hello Chris, thanks for the heads up, problem is I have already bought the new dizzy and its not exactly the same, MY BAD I know
heres a pic of the old one still on the vehicle
and the dizzy I have bought by mistake is this style (this is a library pic, my one is new)
35DLM8
does this meen it wont be compatible for me ? The engine is a TVR 350i
Thanks for your help
Holley
Not sure if it will fit, it most likely will. It looks like you have an SD1 style fitted to the engine, and you have bought a Range Rover style. This way around I think will be OK. Definitely fitting an SD1 type to a Range Rover engine is problematic.
The main thing to watch is the amount of adjustment you have by turning the distributor body. You might find that the vac advance unit or amplifier fouls on the water pump or rocker cover when you try to turn the distributor. You can work around it by removing the distributor and turning it one tooth on the camshaft, but it's all a bit fiddly!
holley
Post by holley »
Thanks chris I will have a look to see if I can get it to fit
Holley
