I've got the chance to buy 4 twin choke 45mm downdraft carbs along with a set of Rover craft manifolds.
I was wondering what you guys think of these carbs.
The lump is a 4.6 with stage III heads and a Piper 285 cam in it. At the moment its running a gas flowed Edelbrock performer manifold and a 500 carb.
I've been told by V8 Dev that they are good carbs but they are tricky to setup, they are critical of fuel pressure, and they ocasionally catch fire
I've also been told by JE Dev that they will be too small.
They don't come with any trumpets, filters or throttle linkage so all that will have to be sorted. Also I'm not sure what to do about the thermostat as that's fitted into the performer manifold at the moment. Obviously there will be some pipework required for the coolant but I don't know if you can buy some sort of remove stat housing.
The vac for the servo will need sorting to!
It sounds like quite a lot of work!
Regards,
Pete
