The link to a previos thread i posted is here http://www.v-8.org.uk/forum/viewtopic.p ... c&start=15 Showing the AFR's, on idle its in the high 11's could this be the prob?
Just to mention the prob again
Bring the car out of the garage, it will normally start up OK on eight, Switch it off without letting it warm up, Go back to it a couple of hours later and it will normally flood two of the cylinders
Another question with Webers
The carbs are Quad Weber 48 DCO'SP's
Any suggestions really appreciated, It drives me Mad
At the mo im using NGK BP7ES, the last rolling road visit the opperator suggested using BPR6ES for normal driving, switching back to 7's for track days etc. What do you reckon? Worth a try? Just thinking with the spec of the engine that it should be 7's? or maybe a different plug to the BP7ES which would be less prone to flooding?
steve
