Injector Calcs.
once paypal sorts its self out and excepts my payment i'll order the bosch green 42lb ones from fiveomotorsport
They are now ordered
just hope they are the right ones now
http://cgi.ebay.com/ebaymotors/ws/eBayI ... 0003703098
cheers stevie,
mmmm whats next to do now
done the pump, now the injectors, changed ecu, anything else?
katanaman wrote:Chevy LSx?
ooooooooooooo marki i wish mate
stevieturbo wrote:fuel lines, map sensor, boost pipes, turbo...ummmmmm gearbox, clutch lol
BUT forced is my next route,
just to make sure i got this right,
my req fuel will be this yeah?
I injector flowrate (cc/min) ( 440 )
D engine displacement (cc) ( 3947 )
N number of injectors (piece, eg. 4 for a 4 cyl port injection) ( 8 )
Simplified equation is: req_fuel = 6.49 * D / N / I
so 6.49*3947/8/440 =7.277 (7.3)
i have got that right aint i
Using the RCEng guide based on 300bhp it works out that you need 23Ib injectors. I assume this is based on the injectors being able to meet all the demands on the engine supplying max power continuously
I also read that running injector that are too large can effect tick over and slow running, is that correct.
here mate:stevieturbo wrote:Where have you got the equation from ?
using the online stuff on RCeng's site is easier. Takes less thinking
http://www.vems-group.org/wiki/index.ph ... torOpening
But what is the equation trying to do ?
Whats it trying to prove ? Is it something specific to the needs of the VEMS ? or a general equation ?
Dont forget, that equation ...
It isnt calculating a general injector sizing question.Assume
* fuel density=0.755 g/cc
* AFR=14.7 at stoich
* intake air density = 0.0012 g/cc (at MAP=100 kPa, which might be a cheat from the real 101..104kPa ?)
* (alternate+1)*divider = N (see N below)
not sure Dave,
what would you recomend?
does it need to be done that way now then???????
and is there a diagram of it mate???
