Removing a RV8 crankshaft pulley?
Rick-Manta
This had been giving me some right grief for ages now. Basically, I have been trying to undo the crankshaft pulley bolt on my nearly stripped down 3.5 engine which is just proving impossible.
Following some advise I've had already: I've got someone to stand on the block which is laying upside down (to stop the whole block tipping over), I've jammed a wooden hammer handle in one of the crankshaft counter weights against the side of the block (to stop the crank itself turning over) and I'm using a long crack bar with all my weight trying to undo the bastard thing to no avail!
Any other ideas please, I'm really stuck?
- Pocket rocket
- Getting There
v8alex
- Helpful or Confused
There's no doubt many techniques to free stubborn bolts....
Have you tried any thread penetrant / releasing agent? I would stand the block edge on and fill the cavity in the crank pulley with PlusGas and leave it overnight then have another go.
Alternatively, take the whole lot to a friendly garage with an air impact driver
Rick,
I would definately spray some release oil (WD40 or similar) on it. use hammer and an old extension bar or steel bar and tap the end of the crankshaft bolt. Then give it some stick with an impact air gun, works for me!
All the best
Steve
All the best
Steve
Live dangerously, syphon fuel, smoke in bed, run with scissors
Rick-Manta
Thanks for the replies. I don't have a impact gun and buying an air compressor is something for the future but not the nearby
I've soaked the thing in plusgas and WD40 but the trouble is I think with the 160 ft lb torque setting. Once I've changed the cam and timing gears, got the cover back on etc, it'll be pretty hard to torque back up by hand.
I could ask the tyre centres, lifting the engine into my boot may be difficult mind!
Thanks again, I'll keep trying.
A good torque wrench will allow you to torque it up but you will have to lean on it pretty hard! (That's why I made a holder for my damper)Rick-Manta wrote:Thanks for the replies. I don't have a impact gun and buying an air compressor is something for the future but not the nearby![]()
